 楼主| 发表于 2016-3-18 11:29 | 只看该作者
Model NO:YC3250FS2PK
Drive:6X4轴距:3300+1410mm
车身长度:7.8米车身宽度:2.5米
车身高度:3.27米轮距:前轮距: 2060 后轮距:1855/1855mm
整车重量:12.2吨额定载重:12.87吨
总质量:25.0吨接近角:20.0度
离去角:30.0度产地:广州
工况:备注:
系别:
发动机
发动机:上海日野P11C-UJ汽缸数:6
燃料种类:柴油排量:10.52L
排放标准:国三/欧三最大马力:350马力
最大输出功率:259.0kW扭矩:1460N·m
最大扭矩转速:1100rpm额定转速:2100rpm
发动机形式:电装电控共轨 增压中冷
货箱参数
货箱长度:5.2米货箱宽度:2.25米
货箱高度:1.3米货箱形式:自卸式
变速箱
变速箱:法士特RT-11509C前进档位:9档
倒档数:1个
轮胎数:10个轮胎规格:11.00-20 11.00R20 295/80R22.5
油箱
油箱容量:150.0L
底盘
车架高度:mm后桥描述
后桥允许载荷:18000kg后桥速比:4.625
弹簧片数:10月13日转向机:Hitachi
1.
GAC HINO 700 Series Dump Truck Specification
Model  :YC3250FS2PK YC3250FS2PM
Driving type ;6×4
G.V.M rating (kg): 25000
Overall dimension(L×W×H)mm: 7850×2495×3270 8420×2495×3270
Dimension of cargo body(L×W×H)(mm)inner: 5200×2250×1300 optional with cover 5600×2250×1200 optional with cover
wheelbase (mm) 3300+1410 3640+1410
Tread width (mm)(front/rear) 2060/1855
Overhang(front/rear) (mm) 1410/1730 1410/1960
Curb weight(kg) 12000,12200(Optional closed cover) 12200,12400(Optional closed cover)
Engine model P11C-UJ
Max. output (PS)kW/r/min (350)259/2100
Max. Torque (N•m/r/min) 1454/1100
Displacement (L) 10.520
Clutch :430 diameter, dry ,single
Transmission RT-11509C/DC12J150T
Axles (front/rear) 8tons/13tons double rear axles
Tire 11.00-20,11.00R20,295/80R22.5
Emission Standard EURO III
Cab F/R Air Suspension Electrical Tiltable Driver Cab
2.
Model YC3310FY2PW YC3310FY2PW
Driving type 8×4
G.V.M rating (kg) 31000
Overall dimension (L×W×H)(mm) 10430×2495×3500 10890×2495×3500
Dimension of cargo body inner 7600×2300×1100(mm) 8000×2300×1000(mm)
wheelbase (mm) 1850+3850+1410 1850+4300+1410
Tread width (mm) (front/rear) 2060/2060/1855/1855
Overhang(front/rear) (mm) 1410/1910 1410/1920
Curb weight(kg) 15100 15300
Engine model P11C-UJ P11C-UR P11C-UJ P11C-UR
Max. output(PS)kW/r/min (350)259/2100 (380)280/2100 (350)259/2100 (380)280/2100
Max. Torque (N•m/r/min) 1454/1100 1594/1100 1454/1100 1594/1100
Clutch DSF-430, dry ,single
Transmission 12JSD160TA ZF9S1820TD 12JSD160TA ZF9S1820TD
Axle GAC HINO 18-inch axle
Tire 11.00R20
Emission Standard GB 17691-2005(EURO III)
就想知道日野后桥速比有哪些,经济转速区间能时速达到多
