General knowledge study guide(2) 基础知识指南
1. As the blood alcohol concentration (BAC) goes up, what happens?
( ) The drinker can clearly see how alcohol is affecting him/her
( ) The effects of alcohol decrease
(x) Judgment and self-control are affected
1. 当血液中的酒精浓度(BAC)上涨,会发生什么?
(3)会影响你的判断力和自我控制能力。
2. Which of these statements is true regarding the use drugs while driving?
(x) Prescription drugs are allowed if doctor says the drugs will not affect safe driving ability
( ) No prescription or non- prescription drugs are allowed at any time, for any reason
( ) Use of amphetamines like “speed” is allowed, if you are using the drug to stay awake
2.下列哪个是关于驾车时使用的药物的正确说法?
(1)医生说的处方药不会影响安全驾驶的能力
3. You will be place out-of service for 24 hours if you Blood Alcohol concentration (BAC) is :
( ) At least 0.2%
( ) At least 0.4%
(x) Any detectable amount below 0.4%
3. 在开车前24小时内,必须保持你的血液酒精含量低于多少(BAC)以下:
(3)任何时间检测都应低于0.4%
4. Which of these statements is NOT true?
( ) Alcohol goes directly from the stomach to the stream
(x) A drinker can control how fast his or her body absorbs and gets rid of alcohol
( ) BAC is determined by how fast you drink, how much you drink, and how much you weight
4.下列哪个说法是错误的?
(2)饮酒者能控制他们的身体快速的吸收和摆脱酒精
5. On which fires can you use water?
(x) Tire
( ) Gasoline
( ) Electrical
5. 哪里着火可以用水?
(1)轮胎
6. Which of these statements is true about warning other drivers of a stopped vehicle?
(x) Move the rear reflective triangle back if the driver’s vision is obscured within 500 feet
( ) Keep the vehicle’s taillight on to warm other drivers
( ) Put out your emergency warning devices within 5 minutes
6.下列哪个是正确警告其他司机禁止停车的
(1)如果驾驶员的视野范围内500英尺,遮挡,移动后方反光三角回
7. Which of these statements is true about engine over heating?
( ) Never shut off an overheated engine unit it cools
(x) Never remove the radiator cap on a pressurized system until the system has cooled
( ) Antifreeze is not needed when the weather is warm
7.下列哪个是关于发动机过热?
(2)切勿卸下增压系统的散热器盖,直到冷却系统
8. For your safety, when you place your reflective triangles you should:
( ) Carry the triangles at your side
(x) Hold the triangles with reflective side toward the oncoming traffic
( ) Keep them out of sight while you to the locations where you will place them
8. 为了您的安全,你应该怎样防止三角形反光镜
(2)举起反光边三角形来向迎面而来的车辆
9. Retarders:
( ) Allow you to disconnect the steering axle brakes
(x) Can cause the drive wheels to skid when they have poor traction
( ) Can not be used on interstate highways
9. 阻滞剂
(2)当情况恶劣牵引时可能会导致驱动车轮打滑
10. Which of the following is not a type of retarder?
( ) Electric
( ) Hydraulic
(x) Robotic
10. 下列哪个不是一个减速类型:
(3)机械
11. What is the proper way to hold a steering wheel?
( ) Both hands close tighter, near the top of the wheel
( ) Both hands close tighter, near the bottom of the wheel
(x) Both hands, on opposite sides of the wheel
11. 手握方向盘的正确方式?
(3)双手握在方向盘的两侧
12. You are driving a long vehicle that makes wide turns. You want to make a left turn from Elm Street onto Oak Street. There are two left turn lanes ( marked ”A” and “B” ) on Elm Street, and Oak Street is four lane streets with two lanes in each direction. You should:
( ) Use left turn lane “A”
(x) Use left turn lane “B”
( ) Start in left turn lane “A” and swing into left turn lane “B” just before entering the intersection
12. 你正在集装箱卡车。你想从Elm Street左转到Oak Street。有两个左转车道(标有“A”和“B”)Elm Street和 Oak Street是在每个方向两个车道四车道街道。你应该:
(2)应该使用左车道“B”
13. Which of these statements is true about double-clutching and shifting?
( ) Double-clutching should only be used with a heavy load
( ) Double-clutching should not be used when the road is slippery
(x) You can use the tachometer to tell you when to shift
13.下列哪个是正确关于双离合和换挡的
(3)您可以使用转速表告诉你什么时候换挡
14. If you have a heavy load that is slowing you down on an upgrade, you should:
(x) Shift into a lower gear
( ) Exit the road until traffic is lighter
( ) Drive on the shoulder so others can pass easily
14. 如果你有一个沉重的负荷,正在放缓你的速度,你应该
(1)转移到一个较低的档位
15. Which of these statements is NOT true about backing a heavy vehicle?
( ) You should back and turn toward the driver’s side whenever possible
( ) You should use a helper and communicate with hand signals
(x) You should back slowly until you slightly bump into the dock
15.下列哪个关于重型车辆倒车是错误的?
(3)你应该慢慢向后,直到你稍微撞到码头
