论坛
搜索
取消
免费下载 聊车用车,都在卡车之家App
【我与乘龙H7】康明斯专家谈H7发动机
追风路人乙
2015-12-18
We have a long-term successfully strategic cooperation with DFLQ, the research and development of ISG have been led by a team in the United States. This global design approach utilizes the latest advanced and lots of Cummins patented technologies, ISG is a new heavy duty power platform for Cummins worldwide. It is built to set new benchmarks in power and torque, fuel efficiency, drivability and reliability. This is just the origin of the ISG name, as the letter “G” means “revolutionary”, ISG is a revolutionary heavy duty power platform.
More safety: Integrated Engine Brake, 25-50% more braking power, safer vehicle operation.
More reliability: ISG features fuel filters with patented NanoNet™ media inside and oil filters which are pre-charged with chemical additives to extend drain intervals of 100,000 kilometers.
Key components integration, having 50% fewer parts to improve reliability and make service easier .
More fuel efficiency:
Adopt Cummins leading three valve technology, which allows more heat used for turbochargers to improve power.
XPI high-pressure fuel injection system helps to improve the injection pressure, which increases the intake and exhaust efficiency for better fuel economy.
Combined with Load Based Speed Control (LBSC), ISG engine has a very good performance with strongerpower, better fuel economy and lower emissions by these integrated technology advantages.
More Light: ISG has the lightest weight in class30% lighter than that of competitive engines. It helps to reduce the vehicle weight and improve capacity and efficiency of vehicles.
I can be responsible to say: ISG is a world class engine, "you are worth it!"
我们与东风柳汽有着长期成功的战略合作,此次匹配的ISG发动机由康明斯美国团队主导设计并开发,采用全球联动的设计模式,采用了康明斯多项专利技术,是康明斯全球范围内最新的重卡动力平台。在提升动力和扭矩、燃油经济性、安全性和可靠性方面均实现了新的突破。这也是这款发动机名称的来源。”G”就是革命的意思,这是一款革命性的重型动力平台。
更安全:发动机缸内制动,制动功率提升25-50%,大幅提高了行驶安全性
更可靠:ISG采用康明纳米介质燃油滤和内置增效缓释剂的革新机油滤,保养周期可延长至10万公里。关键零部件与整机的有机集成,整机零件数量降低50%,可靠性更高,维修更便捷。
更省油:采用国际领先的康明斯三气门技术,让更多热量用于涡轮增压器,从而提升了动力,采用当今最先进的康明斯超高压燃油喷射系统,提高燃油喷射压力,提高了发动机进排气效率,再配合智能转速控制技术,这些集成的技术优势显著提升了发动机的动力性、经济性和排放水平,显著降低燃油消耗。
更轻:发动机自重相比其他品牌同类机型减轻30%,有效降低整车自重,提高了车辆运载能力和效率。
我可以负责任的说,这是一台世界级的发动机,“你值得拥有”!
打开卡车之家看图省50%流量立即打开
打开卡车之家App查看更多精彩内容
推荐内容
游客,您好!
最热帖子
最新帖子
