论坛
搜索
取消
免费下载 聊车用车,都在卡车之家App
考美国A照看这个就行了!来自美国卡友马丁的真实考题分享~
卡家大白
卡家大白
2016-09-22
自从美国卡友马丁的视频在论坛内发布后,论坛里面刮起了一股美国卡车风。也有很多的卡友私信马丁在美国开卡车的各种问题。其中驾照考试问题是大家问的最多的,包括考试题都考啥?我们看不懂怎么办?
针对于这种情况,卡友马丁给大白发来了一份美国真实的A照考题,卡友们可以来看看学习一下~让我们在这里感谢马丁所提供的资料!这些题目的翻译都是马丁和他的爱人一条一条翻译的,足可见这些资料的珍贵!
考题中的刹车题、复合题、基础题是A照必考的,BUS如果不考的话可以不看,混合题的意思就是把所有的题目都打乱了,作为自己测试用,以前只有三套考题,所以很多人只背答案来考试,现在考试都使用电脑版,每次都是随机出题,所以混合题就更为重要了。
前排高能提醒!海量考题来袭!由于篇幅较长,大白会分段进行发布~
Air Brakes(1)
空气制动系统
1. The parking or emergency brake on a heavy vehicle can only be held in position by something that cannot leak a way, like:
(x) Spring pressure
( ) Air pressure
( ) Hydraulic pressure
1. 重型车辆停车或紧急制动不能改变只能保持适当位置的,如:
(1)压力弹簧
2. Modern air brake systems are three different systems combined together. They are the service, parking, and the ________ brakes.
(x) Emergency
( ) Foot
( ) S-cam
2. 现代空气制动系统有三种不同的系统结合在一起。他们是驻车档,和____刹车
(1)紧急制动
3. The air supply pressure gauges shows how much pressure:
(x) Is in the tanks
( ) You have used in this trip
( ) Is going to the brake chambers
3. 气压表是显示什么的供气压力:
(1)气压罐
4. The parking or emergency brake of trucks and buses can be legally held on by ____pressure
(x) Spring
( ) Fluid
( ) Air
4. 卡车和公共汽车的停车或紧急制动,可以由____和压力组成
(1)弹簧
5. All air brake equipped vehicles have:
(x) An air supply pressure gauge
( ) An air use gauge
( ) A back up hydraulic system
5. 所有空气制动的车辆都配备:
(1)供应空气压力表
6. The stop light switch:
(x) Turn on the brake lights to warn drivers behind you
( ) Tells you when you need to use your emergency brakes
( ) Tells you when the air brakes system is low on air pressure
6. 刹车灯开关的作用:
(1)打开刹车灯,提醒你身后的司机
7. When you apply the brakes, the brakes shoes/linings are pressed against the:
(x) Brake drum
( ) Slack adjuster
( ) S-cam
7. 当您刹车时,刹车踏板/衬板连接着:
(1)制动鼓
8. If your vehicle has an alcohol evaporator, it is there to:
( ) Rid the wet tank of alcohol that condenses and sits at the bottom
( ) Eliminate the need for daily tank draining
(x) Reduce the risk of ice in air brake valves in cold weather
8. 如果您的车辆有酒精的蒸发器,它能:
(3)在寒冷的天气能够减少冰凝结在空气制动阀门的风险
9. Why should you drain water from compressed air tanks?
( ) The boiling point reduces braking power
(x) Water can freeze in cold weather an cause brake failure
( ) Water cools the compressor too much
9. 你为什么要排出压缩空气罐的水?
(2)水在寒冷的天气会冻结从而导致刹车失灵
10. If air pressure does not build up fast enough within the correct amount of time:
( ) You should ready to use parking brake to help stop
( ) The alcohol container may be low
(x) Your air pressure may drop too low during driving
10. 如果没有足够的时间增加空气压力:
(3)你在驾驶的时候空气压力可能下降过低
11. The driver must be able to see a warning before air pressure in the service air tanks falls below ___ psi
( ) 50
(x) 55
( ) 80
11. 当空气罐中的空气压力低于____ PSI时,司机能够看到一个警告
(2)55
12. The spring brakes used on tractors and straight trucks will bring your truck to a stop when the air pressure drops below _______ psi
(x) 20
( ) 60
( ) 100
12. 当气压低于_____磅时, 弹簧拖拉机和卡车上使用的刹车会使你停车
(1)20
13. How should you check that your service brakes are working properly?
( ) Park on slight incline drain off air pressure set the parking brakes and check for movement
( ) Park on level ground chock the wheels engage the parking brake shut the engine off
(x) Wait for normal air pressure release the parking brake move the truck forward slowly and apply the brake firmly using the brake pedal
13. 你应该如何检查您刹车是否正常工作?
(3)踩下不放卡车的制动与刹车踏板,等待正常的空气压力释放,刹车踏板缓缓向前移动到正常位置
14. To check the brake slack on S-cam brakes, you should park on:
( ) Level ground and apply the parking brakes
(x) Level ground chock the wheels release the parking brakes
( ) A slight grade releases the parking brakes and apply the service brake watching for vehicle movement
14. 发现S-CAM刹车制动松弛,你应该停在:
(2)平整的地面,在每个轮子前后塞满阻碍物,关闭停车制动器
15. The air brakes system for a straight truck or bus should not leak at a rate of more than _____ psi per minute with engine off and the brakes released.
( ) 1
( ) 3
(x)2
15. 一辆平直的卡车或巴士的空气刹车系统,关闭发动机和关闭手动制动器,不应该泄漏率每分钟超过___PSI
(3)2
16. The air loss rate for a straight truck or bus with the engine off and the brakes on should not be more than:
( ) 1 psi in one minute
( ) 2 psi in 45 seconds
(x)3 psi in one minute
16. 关闭发动机和刹车的卡车或巴士的空气损失率应不超过:
(3)1分钟3磅
17. The safety valve is set to automatically reduce pressure at _____ psi
( ) 50
( ) 100
(x) 150
17. 安全阀的设置为自动减少_____ PSI的压力:
(3)150
打开卡车之家App查看更多精彩内容
推荐内容
热门回帖
全部回帖
首页1/6下一页末页
游客,您好!
最热帖子
最新帖子
